2007 Tahoe 4.8L bottom end knock at operating temp
Old Jan 18, 2021 | 1:15 PM
Wallnutz123's Avatar
Default 2007 Tahoe 4.8L bottom end knock at operating temp
Hey guys! New to the forum but had a question that I havent seen asked in any forums.
So my 07 Tahoe has a bottom end knocking problem but it only happens after it hits op temp. Once it starts knocking it only lasts about 5-6 mins then completely goes away. I can definitely tell its louder when you are under the engine. No CEL. I heard something about a clogged screen in the oil pick up line or could be a wrist pin problem but im stumped. I just want to see if any of you guys have had this problem before and have any insight before i start tearing in to the engine.
Any help is apperciated!
Thanks in advance!
Old Jan 19, 2021 | 6:20 PM
oilcanhenry's Avatar
Thanks in advance!
How many miles do you have on your Tahoe?
Old Jan 19, 2021 | 6:53 PM
It has 145k on it
Old Jan 19, 2021 | 6:56 PM
It has 145k on it
Thats nothing, Are there any leaks or damage under the vehicle?
Old Jan 19, 2021 | 6:57 PM
No sir. Clean as a whistle.
Old Jan 19, 2021 | 7:21 PM
Does it use motor oil at all? How is the oil pressure?
Old Jan 19, 2021 | 7:25 PM
No oil consumption at all and pressure stays around 40 at idle and goes to about 55 or so when accelerating.
Old Jan 19, 2021 | 7:48 PM
That is good and quite normal that your oil pressure is within a good range. And you are pretty sure it's a lower motor part that is causing this? Intermittent issues like this one are difficult to diagnose. Are you the first owner of your Tahoe?
Old Jan 19, 2021 | 9:17 PM
Im pretty sure its coming from the bottom end. You can hear it from the top of the engine bay but its more distinct when I go under the oil pan. No I am the second owner. I purchased it at about 85k miles
Old Jan 21, 2021 | 2:16 AM
Pretty sure its rod knock, but that's usually pretty constant. not intermittent. No telling what and how he/she treated the motor like, but likely not as well as he/she could have. Or it could have been a defect when the motor was built as well.
