2007 Tahoe 4WDBrand new rear shocks loose on mounting bolt.
Old Feb 17, 2018 | 2:13 PM
zach323's Avatar
Default 2007 Tahoe 4WDBrand new rear shocks loose on mounting bolt.
Hi all,
I'm new here I just replaced ALL of the shocks/springs on my Tahoe a couple of weeks ago.
I used the correct ACDelco parts. However, the new rear shocks are loose on the upper mounting bolt. The mount and bolt ARE NOT loose, the upper shock mounting hole seems like it's way too big and just wobbles around the bolt. This makes driving very annoying because there is a constant rattle in the rear suspension.
I verified the issue by climbing under the rear and watching the top of the shock bounce around on the mounting bolt as I pushed up and down on the frame.
Any suggestions? The old shocks didn't do this...
I am thinking about just returning them and putting on a different brand but wanted to check here first before going to all that trouble.
thanks.
Old Feb 17, 2018 | 3:26 PM
Welcome to the forum.
How does the upper end on the new ones compared to the old ones? Was there supposed to be a rubber bushing in them? Not sure how they're mounted on the current Tahoes but the rear shock upper ends used to be bolted directly to the mount and the lower end had the rubber bushing in it.
Old Feb 20, 2018 | 3:47 PM
Off the top of my head I would suspect that the nut and bolt are not tight enough, or the hole that the bolt passes through is too big, the bolt should just fit in the shock mounting hole...
Old Feb 18, 2020 | 11:08 AM
Woodworking Next's Avatar
Default 2010 Tahoe rear shocks
I have the same issue, and verified bolts part number with dealerships and is just the bolt to the frame.
I am doing bushings to fit the frame and close the elongated holes, hopefully will work.
If somebody has done different repair plese posted, Thanks!
QUOTE=zach323;352968]Hi all,
thanks.[/QUOTE]
07TahoeLTZ---
Apr 2, 2015 6:19 AM
PatStein
May 4, 2013 8:10 PM
ccooper
Uplander
Sep 2, 2010 1:33 AM
cams 98 silverado
Mar 9, 2008 5:06 PM
blazerman
Feb 22, 2008 10:32 PM
