2007+ Tahoe Add-an-Amp
Old Jun 28, 2019 | 11:21 PM
  #41
Jarvis Handy's Avatar
Originally Posted by Cruester
Okay so i run the 12 the yellow postive wire from the conveter to the box by the brake pedal. Does it matter what wire. Also am i splicing the wire into the postive at that black box?
Old Mar 29, 2020 | 7:15 PM
  #42
Gregory Joseph's Avatar
Do you plug the factory sub back in after tapping into it?
Old Mar 29, 2020 | 7:27 PM
  #43
Cruester's Avatar
you dont have to unhook it,I never did! I used a toggle switch to kill the remote wire when I choose to so just the factory system works !
Old Mar 19, 2022 | 10:02 AM
  #44
Schitzweac's Avatar
Default Go LOC less
Originally Posted by socaliguy81
Well, after a lot of searching for the Bose Nav/DVD/Rear Ent wiring diagram, I finally found the only useable signal for adding a sub amp. The issue I had was that tapping the speaker wires on the Bose system changed the impedence too much and threw the Bose amp into a state of confusion. The only logical reasoning behind this is that Bose uses an auto-clip-sensning system that basically tells the amp how much stress the speaker is under through the language of impedence. Notice how when you rotate your volume **** all the way up, it just magically knows when to stop? I realized also that adding an amp for mids and highs would have to be done by grabbing the low level signal before the Bose amp FYI.
Attachment 15201
The center console subwoofer is practically located under the dash. After learning that the Bose amp was in the center console at the rear under the storage area, I figured there must be high level sub signal traveling through the center console.
Attachment 15202
Attachment 15203
Sure enough, I popped out the very easily accessible storage tray and spied a 4-wire harness. You might be thinking only 1 pair of wires go to a sub. Well, as I learned when adding an amp to my CTS w/ Bose, they like to run 2 pairs, one for each voice coil. All you have to do is tap each pair and run to a line-level adapter or hi-lo converter as some of you know them by. The wiring is as follows:
***These colors are on the amp side of the plug. The sub side has different colors all together.***
Voice Coil #1 aka Channel 1
+Dark Blue w/ White Stripe
- Light Green w/ Black Stripe
Voice Coil #2 aka Channel 2
+Dark Green
-Light Blue w/ Black Stripe
***THESE ARE SUB LEVELS NOT FULL RANGE..TAPPING THESE WIRES ARE ONLY FOR INSTALLING SUBS***
**Since it is easier to tap the larger gauge wires on the sub side of the harness, just use the plug's corresponding letters (ABCD) to match the wires up.**
Attachment 15204
There is plenty of room under most second row seating for one large amp or multiple smaller amps. Even the factory beauty board can be cut to easily flush amps in and hide wiring.
Attachment 15205
Attachment 15206
The 12Volt Main and 12Volt Accessory/Ignition wire locations are pictured below.
Attachment 15207
Attachment 15208
Attachment 15209
Attachment 15210
Attachment 15211
Attachment 15212
I am a professional installer who works out of Southern California and would love to help out if anyone needs.
760-773-8728 Travis Brown
socaliguy81@yahoo.com
If running a stock HU. Just solder 2 -16awg speaker wires to sub out and connect to high level on your amp. Match polarity and ground and run on milli -2 volt setting. No need for a line out converter...
socaliguy81
13
Sep 25, 2019 3:44 PM
CoffeyLover
Apr 5, 2011 12:17 PM
AMGfan
Nov 5, 2010 2:09 PM
Big Pappa
Nov 2, 2010 11:26 AM
