2007+ Tahoe Add-an-Amp
Old Sep 3, 2018 | 4:09 PM
  #31
Yep, I just reset the password and logged in at socaliguy81. I didn't notice any bans placed on the account. I sent you a PM.
Old May 9, 2019 | 9:44 AM
  #32
Cruester's Avatar
Default 2010 tahoe pin 0 is pin 6?top left plug !
Originally Posted by socaliguy81
Well, after a lot of searching for the Bose Nav/DVD/Rear Ent wiring diagram, I finally found the only useable signal for adding a sub amp. The issue I had was that tapping the speaker wires on the Bose system changed the impedence too much and threw the Bose amp into a state of confusion. The only logical reasoning behind this is that Bose uses an auto-clip-sensning system that basically tells the amp how much stress the speaker is under through the language of impedence. Notice how when you rotate your volume **** all the way up, it just magically knows when to stop? I realized also that adding an amp for mids and highs would have to be done by grabbing the low level signal before the Bose amp FYI.
Attachment 15201
The center console subwoofer is practically located under the dash. After learning that the Bose amp was in the center console at the rear under the storage area, I figured there must be high level sub signal traveling through the center console.
Attachment 15202
Attachment 15203
Sure enough, I popped out the very easily accessible storage tray and spied a 4-wire harness. You might be thinking only 1 pair of wires go to a sub. Well, as I learned when adding an amp to my CTS w/ Bose, they like to run 2 pairs, one for each voice coil. All you have to do is tap each pair and run to a line-level adapter or hi-lo converter as some of you know them by. The wiring is as follows:
***These colors are on the amp side of the plug. The sub side has different colors all together.***
Voice Coil #1 aka Channel 1
+Dark Blue w/ White Stripe
- Light Green w/ Black Stripe
Voice Coil #2 aka Channel 2
+Dark Green
-Light Blue w/ Black Stripe
***THESE ARE SUB LEVELS NOT FULL RANGE..TAPPING THESE WIRES ARE ONLY FOR INSTALLING SUBS***
**Since it is easier to tap the larger gauge wires on the sub side of the harness, just use the plug's corresponding letters (ABCD) to match the wires up.**
Attachment 15204
There is plenty of room under most second row seating for one large amp or multiple smaller amps. Even the factory beauty board can be cut to easily flush amps in and hide wiring.
Attachment 15205
Attachment 15206
The 12Volt Main and 12Volt Accessory/Ignition wire locations are pictured below.
Attachment 15207
Attachment 15208
Attachment 15209
Attachment 15210
Attachment 15211
Attachment 15212
I am a professional installer who works out of Southern California and would love to help out if anyone needs.
760-773-8728 Travis Brown
"socaliguy81@yahoo.com"
Pin 0 I believe is pin 6 on a 2010 tahoe!
Old Jun 28, 2019 | 9:51 PM
  #33
Jarvis Handy's Avatar
Originally Posted by Cruz H
I got a 2008 tahoe i want to know what are the speakers colorcodes from the bose amp because i want to run wires from the center speaker wires to my new amp
Did you ever find out what colors went to what wires
Old Jun 28, 2019 | 9:58 PM
  #34
Cruester's Avatar
Old Jun 28, 2019 | 10:05 PM
  #35
Cruester's Avatar
U will need a high to low converter to run to ur amp ,I have a 2010 tahoe and used a high to low to my amp after wiring it from before the amp wires in center console!works great!
Old Jun 28, 2019 | 10:06 PM
  #36
Cruester's Avatar
Old Jun 28, 2019 | 10:08 PM
  #37
Cruester's Avatar
If u have further questions hit me up on messanger!marlin goulet!
Old Jun 28, 2019 | 11:08 PM
  #38
Hey so i bought the loc2slsd converter and ran the ground to a ground and power to a power.
Then i hooked up the respective wires to the wires on the amp. What i know so far is
From the amp
[ ] Dark Blue white stripe - postive
[ ] Light green/black -negative
[ ] Dark Green - postive
[ ] Light blue/black - negative
It still won't turn on. Amp wont even turn on
Now when i ran the converter to the rear speakers everything worked fine. Just lookes messy
Any tips!?!?!
Old Jun 28, 2019 | 11:12 PM
  #39
Cruester's Avatar
Gotta run the amp turn on wire under the dash by the brake pedal is a black cover,theres a spot in there to run the turn on to!
  #40
Cruester's Avatar
