2007 tahoe AFM removed now the car will not start
Old Apr 3, 2018 | 9:29 AM
tex96's Avatar
Angry 2007 tahoe AFM removed now the car will not start
my wife's 07 Tahoe gave us a service message about a month ago as we were driving. It said service stablitrack and traction control off. We stopped the car as soon as we could and it had a very rough idle. I started by changing the plugs and wires but nothing helped. Towed the car home and it sat for about a week until i had time to mess with it. After removed parts and replacing a few sensors, I finally found the problem. We had a collapsed lifter. I did some research and found that the AFM system was a nightmare. I decided to the remove the AFM parts. The car sat for about 3 weeks. Last week I was off from work so I started the process of tearing down the motor to remove and replace the AFM parts and some general parts that due to the age and mileage on the car. The parts that we replaced are the following. Head gaskets, head bolts, valley cover plate, lifters, timing cover gasket, lifter guides, cam thrust plate, cam shaft, water pump, oil pump, timing chains and gears, tensioner, exh manifold, and intake manifold gaskets, belts, and had the ECM reprogrammed. I got all of this changed out and put oil and water back in the car the ECM was installed and when I went to crank the car nothing happened. I have dash lights, headlights, door locks work, rear windshield wiper works but the front wipers do not. I took the starter back off and used the jumper cables to tell if the solenoid would work and it does. When I reinstalled it on the car the purple wire has no power running through it. I'm read a few things about the BCM going bad but not really sure that is my problem. I finally got a code on it and it was U0102 which is lost communication with transfer case control module. any help would be great appreciated.
2007 Chevrolet tahoe
5.3 L Vortec
z71 4 wheel drive
flex fuel
U0102 Lost Communication with Transfer Case Control Module (TCCM)
Read more at: https://www.obd-codes.com/u0102
Copyright OBD-Codes.comU0102 Lost Communication with Transfer Case Control Module (TCCM)
Old Apr 4, 2018 | 8:20 AM
which module or modules set the lost communication with the tccm?
Is the code active or stored?
-any theft deterrent issues after the ecm programming? Inform the programmer...maybe they have some input?
Old Apr 4, 2018 | 8:41 AM
tex96's Avatar
I dont see any theft issues, the light is not blinking or staying lit. I called the programmer and he thinks that it may be a bad BCM module. Would the BCM module cut the power to the starter wire?
Old Apr 4, 2018 | 8:14 PM
it could; if there is a communication fault.
