2007 tahoe clunking in rear sups.
#11
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> djvinevibez,
I replied to your private message regarding this issue.
Louis
GM Customer Service
![Big Grin](https://chevroletforum.com/forum/images/smilies/biggrin.gif)
Louis
GM Customer Service
#12
Investigate any rear end issues as soon as possible. My 2007 tahoe has had the rear end replaced twice. The first time it went out again after 5 months. After the second replacement it has held up well. I do not do any towing. It is used for normal driving.
#13
Well i took mine in and all they did was lube the slip yoke up. What where the detailed problems with your suspension. I only have about 5 months left on my 5yr/100k warranty so i need to get things fixed fast
#14
I had the clunking but also a scraping sound that appeared to be coming from the rear wheel area. It was a consistent sound vs. periodic. The dealer diagnosed it as a parking brake issue and said that it was dragging. They tried to fix it twice with no success. I went to independent shop for tires and told them to just replace the entire rear brake system because I was tired of the scraping noise. It took them 5 minutes on the rack to tell me that it was the rear end rather than the brakes. I had a re-build done on the rear-end which worked well for 5 months and then very suddenly went out. I then had the entire "chunk" replaced and have had no problem in the past year. I was out of warranty and these two repairs cost me around $4k combined.
This has been the lowest quality vehicle I have every owned which is unfortunate since I love the design and the way it drives when working. More shop time on this one vehicle than my previous 5 combined. I've shelled out $8k easily since my warranty expired. I would have to pull the paperwork to create a list of all the obscure sensors, electronics, and other things that have failed in the past 3 years. The power steering pump is going out now. I think the Toyota Sequoia will be in my garage soon.
#15
A rebuilt rear-end that only lasts five months was done incorrectly or abused. Did the shop inform you what was making the "scraping" noise that req'd a rebuild?
jzaldivar
December 6th, 2010 11:00 PM
sgmstr
June 24th, 2010 11:37 AM
pahapoika
June 6th, 2010 6:58 PM
Mike Sigmond
23
September 22nd, 2009 5:18 PM
dmacauley
August 23rd, 2007 9:24 AM
