2007 tahoe dvd problem
Old Oct 11, 2007 | 4:03 PM
cliwea's Avatar
Default 2007 tahoe dvd problem
I have a 2007 tahoe ltz. It came with the 6disc radio cd. I brought a cd/dvd head unit and the rear entertianment console to install. the parts man at my dealership says i have to replace the whole wiring harness in the dash and also buy one for the roof. Does anyone have any knowledge on the subject??
I thought gm would use the same harness for most of the top line model tahoe if you wanted to upgrade..
I need some help!!!!
Old Oct 13, 2007 | 7:12 AM
ZX1100F1's Avatar
Default RE: 2007 tahoe dvd problem
GM uses a body wire harness based solely on the options and equipment that the unit is to have installed.
You don't have to replace the dash wiring, the bad part is that you will have to build and splice your own harness in for the rear DVD screen, this is the reason that GM does not offer the OEM flip-down screen as a dealer installed item through GM Accessories.
I personally think that the better (and easier) way to go is to install the GM headrest DVD system.
patman3065
Nov 22, 2022 9:34 AM
73shark
Jun 27, 2011 8:46 PM
cjasonsmith
Feb 21, 2009 10:50 PM
tahoelovah
Oct 7, 2007 7:17 AM
RouDaddy
Jun 26, 2007 6:14 AM
