2007 Tahoe Engine
Old August 20th, 2013 | 7:15 PM
TAHOE122's Avatar
New User
Awaiting E-mail Confirmation
Default 2007 Tahoe Engine
I just found this forum and havent searched alot around here. Last year my 2007 tahoe started with a bit of rod knocking and took it to the dealership and was told about a problem with chevy making 07 engines with a problem with alot of oil consumption. Two weeks ago my rod knocking got worse and i believe one piston is out. Ive called serval junkyards and havent found a replacement engine I would like to know if anybody on here knows any good with high reputation places online where I could possibly order and engine. thanks Im located in Washington state.
Old August 20th, 2013 | 8:38 PM
Welcome to the forum....
Do some searching for AFM (Active Fuel management)
Its possible you may only need to have the upper engine rebuilt ( lifters and cam)
have you pulled the plugs and inspected for oil? have you done a compression check?
Old August 21st, 2013 | 6:12 AM
Headache Ball's Avatar
Yeah man the bottom end of those engines is pretty tough. Are you POSITIVE that it is a rod knock? I would verify that by removing the valve covers and starting the engine. If it's stopped in the right spot, you may not even have to start it. If you have a loose rocker arm and it is a valvetrain rattle instead of a knock, you may be fortunate to just have an AFM issue. Keep us posted!
tbarkermn
June 17th, 2016 10:25 AM
konasmrz
December 9th, 2012 2:17 PM
konasmrz
77
September 29th, 2009 10:54 PM
massattitude
May 4th, 2007 6:51 PM
