2007 Tahoe Fuel Lines
Hi Y'all,
I'm sure people are going to say its a bad idea, but I bought a couple of those magnets that are supposed to help improve gas mileage. Hey, with raising gas prices, its worth the $10 to see if they work.
Anyways, they need to go on the fuel lines, as close to the engine as possible. However, I'm not exactly sure that I've found the right lines. When I look from under the truck from the tank to the engine, I see two lines (silver color) running from apparently the gas tank up the left side to just pass the drivers door, then they move to the center head up towards the front and come up to the engine right in from of the passenger seat. From their each one T-Splits, into 4 lines, two go to the passanger side of the engine in the front near the middle (up/down), I'm not sure where the other two go after the split (I lose them). I'm pretty sure they are the fuel lines, but just thought I would ask to be sure.
Also, if I am right that there are two fuel lines, I'm assuming that there's two because of the AFM. If you can clarify this I would appreciate it.
Hey, if it works it works, if not I'm out $10 and remove them. I've see lots of testimonials on these things, so what the hell...
Thanks for any input...
To get as close to the engine as possible, you need to be under the hood, not under the vehicle. The fuel line closest to the engine is on topandat the rear of the engine.
Be sure to chant the proper incantation while installing the magnets, otherwise when you start the vehicle, it will rain horseshoes and turkeys.
ORIGINAL: RonH
Of course, I never found just one line that I could guess was the fuel line, I found two lines coming from the tank, but come into the engine compartment in front of the passenger and then did T splits like I described in my post. With what little I know about engines, I didn't expect to see this, I expected to see just one line. On the old car I had, I found the fuel line very easy... just not quite sure on this truck...
Thanks for the tie down suggestion, I plan on using a few extra tie downs to make sure the magnets don't move...
Thanks for the help, I am still a little unsure about which line(s) is/are the fuel line(s)... any more guidance would be greatly appreciated.
The fuel line will have a schrader valve (looks like an oversized tire air valve) for releasing the fuel pressure in the fuel line. It should be behind the throttle bodyon top of the engine and should be pointing straight up. Find the fuel pressure release valve and you have found the fuel line.
If a $10 magnet would improve fuel economy don't you think that the manufacturers would build it into the vehicle?
They have all tested the magnets and found that they do nothing to improve efficiency but they will cure cancer.
ORIGINAL: ZX1100F1
Also, I think I found what RonH was mentioning... On the top of the driver's side of the engine, line with a valve in it... it has a blue cap on it... sound about right?
ORIGINAL: 73shark
Sounds like we have a buyer for a Turbonator which coupled with a TB spacer will not only get you a 25% mpg increase but 30 hp.
Also, I did put the magnet on my old car, and whether it was from the magnet or paying more attention to my driving I got consistently about 1 to 2% better mpg, which did translate into about a small overall savings.
ORIGINAL: RonH
ORIGINAL: gdf7279
but some would say that the big automakers benefit from the consumption of fossil fuels..
Oil companies make more profit then any other companies on the planet they sure as heck don't need to payoff automobile manufacturers.
Many GM vehicles currently will operate very well on E85 but it is estimated that fewer then 5% of the vehicles owners buy it.
