2007 Tahoe - Low Coolant - No Heater
Old Apr 8, 2011 | 12:37 AM
kody1979's Avatar
Default 2007 Tahoe - Low Coolant - No Heater
Last weekend my cabin heater stopped working and in troubleshooting that I saw people saying that low coolant level could be the cause. Both rear and front heaters were blowing cold or luke warm air. I filled my reservoir, which was a little low, and after a short drive the heat was working again. I haven't driven it a ton since then so I don't know if it is permanently fixed or not yet. Temperature gauges are always spot on 210 or whatever the center mark is once the engine warms up.
Here's what I need help with:
For the last couple of years I've noticed that the coolant level in my reservoir is about 1 inch below the cold line. Whenever I change the oil, I will usually top it off but it continues to drop to about that 1 inch line and never really any further. I can't find any visible leaks and my oil always looks clean. Why would the coolant keep dropping?
Old Apr 8, 2011 | 2:22 PM
pressure test the cooling system and see if you get a pressure drop. If it does drop look for external leaks.
typically they leak from the water pump gasket.
Old Apr 12, 2011 | 6:14 PM
plier's Avatar
It could also be the intake manifold gasket. When they leak they will drip down the back of the motor.
dlaroche
Oct 29, 2014 7:17 PM
s2002h69
Nov 11, 2010 5:32 PM
erik2282
Aug 15, 2009 4:45 PM
angieman
Oct 19, 2006 12:00 AM
viking
Oct 11, 2006 11:14 PM
