2007 tahoe ltz dash has cracked????????
Old May 3, 2024 | 11:23 AM
  #1381
mhanlen's Avatar
Originally Posted by cmetz
Hello, I have that typical dash crack in my 2013 SSV. at first it was a crack that opened up a bit in cold weather and closed again in warm weather. Did anyone find a better solution, even not perfect? I heard about there are shells one could put over it, to cover the top of the dash all together. Are those still sold? (are there places that install them.
No repairs work. It's like putting a new roof over a rotten frame. The dash will continue to crack. When the crack meets another crack, it will fall into the frame. I've replaced and repaired, nothing has lasted more than 4 years. I have noticed the part number has changed, maybe the material has improved. It's a gamble. Good luck.
Old May 3, 2024 | 3:09 PM
  #1382
Pierregirard's Avatar
Originally Posted by bamafutbal
noticed a crack in the dash today, 3-4 inches long. no idea how this could have happened. anyone else??? also does anyone know where i can get a replacement new or used (but has to look new)
thanks
john
gainesville fl
What did you do with it???
Old Sep 19, 2024 | 8:13 PM
  #1383
_GMAN_'s Avatar
Does anyone have opinions on the fiberglass dash covers? I’ve been seeing them a lot on Facebook Marketplace.
Old Sep 20, 2024 | 4:56 AM
  #1384
spunebil's Avatar
I have one in my 2007 suburban LTZ, except mine isnt fiberglass. Its a black Plastic , I have had it for a couple of years now, one of these days I will mount the dbl stick tape so it doesnt slide around , it some times slides back enough to block defrost vent for windershield. I just nudge it back ( its only an inch or so Mine has the cut-out for pass. airbag and should last longer than this suburban will, if It dont, I will get another one . it only set me back a little under a hundred bucks.
Old Sep 20, 2024 | 5:56 PM
  #1385
_GMAN_'s Avatar
You have the top dash cover. I am looking to replace the entire dash. The one I am looking at is a complete dash cover swap.
ericnottelin
Oct 30, 2012 10:22 AM
Barry_A
Jun 27, 2010 9:23 PM
ChevyguyArmen
May 3, 2010 8:24 PM
