2007 TAHOE PROBLEMS POST THEM HERE!
Old Oct 30, 2006 | 10:46 AM
  #11
maynard_tim's Avatar
Default RE: 2007 TAHOE PROBLEMS POST THEM HERE!
Hi, have had mine for about 5 months. Have only had a few problems, here they are. First, look at the underneath of your truck, my says its from Arlington, Tx, The whole underneath is rusted, bad enough the paint is comming of the rear end housing, and was one spot under the hood, Dealer said all normal abut the hood, and did fix it. The right rear door step panel, was broke, they replaced it. The lift gate makes noise, only when towing a box trailor though. Ok this one bothers me, it makes alot of body noise, like sqeaking or rubbing noise, read some post, and have cleaned and put on some wd-40 around the doors, still squeaks. Need help with this one. Got two new ones latly, just in the last week or so, and have not got a chance to get back to the dealer yet. Sounds like the transmission is whinning now, and my sterring wheel is loose. IF you hold it at the top it has about an eight of an inch movement in it, but not from the sides, I know thats small, but its new, I notice, and it bugs the hell out of me. Other than them things, All is good.
Old Oct 30, 2006 | 11:05 AM
  #12
lagger's Avatar
Hey, mine is from Arlington too and I noticed all the rust under the 'Hoe too yesterday when I was doing an oil change. Is this normal?? Dont remember seeing this kind of rust under my old truck.
Old Nov 6, 2006 | 9:36 PM
  #13
infoblocked's Avatar
Does anybody else hear a squeak when they turn their steering wheel? It's probably just a rubber flap rubbing when the wheel turns but now that I've noticed it I can't help but hear it everytime I turn the wheel.
Old Nov 7, 2006 | 12:51 AM
  #14
Just changed mine and to only rust I noticed was on the unfinished steel parts like tie rods and spindles. The frame, sway bar, cross members, etc all had some time of black rubber-like coating on them. Should last longer than the frame paint they used to use.
biglg
Nov 10, 2025 4:15 PM
MalibuMaxxSS
Mar 26, 2019 1:07 PM
MEVtopsail
Jul 24, 2011 8:47 PM
MEVtopsail
Aug 24, 2006 5:52 PM
