2007 Tahoe Radio whirling noise
Old Oct 26, 2010 | 12:55 PM
Brandon2007Tahoe's Avatar
Default 2007 Tahoe Radio whirling noise
What is running inside of my radio on 07 Tahoe? I here a motor sound in there when I turn the car off and leave the radio on with volume on mute. thanks.
Old Oct 26, 2010 | 6:38 PM
Its a cooling fan...
Old Oct 26, 2010 | 6:58 PM
ah ha! Thanks! How long can I run the radio with engine off before my 2007 tahoe battery dies? anyone know?
Old Oct 26, 2010 | 7:06 PM
Its not just the radio that runs, there are several modules that are powered on at the same time.... I'd give it a max of 20 minutes before the battery indicator would light at start up...
Old Oct 26, 2010 | 7:47 PM
i have been reading in these forums about adding a second battery but the wiring and charging issues of the second battery may be beyond my abilities. anyone have comments after completing this process or can offer instructions with pictures? thanks.
Old Oct 26, 2010 | 8:44 PM
The charging system of your Tahoe is capable of charing 2 batteries without issue.. in fact its setup to charge an extra battery that would be on a trailer... that is what the extra fused stud is for on the under hood fuse box...
The options for you would be to have the battery isolated or to be in series with the factory one....
Old Oct 26, 2010 | 8:46 PM
If you read the owners manual for the "tow haul" mode button it indicates that it enables the alternator to output a higher voltage for charging a trailer battery...
Old Oct 26, 2010 | 8:49 PM
I hope you meant in "parallel" with the factory one. 24V would probably kill most, if not all, of the electrical stuff.
Brandon2007Tahoe: Search this forum as I recall someone posting some info on an isolated second battery. Also the noise may be the Nav DVD drive.
Old Oct 27, 2010 | 7:18 AM
Correct, not literally in series but in a non-isolated state, meaning both batteries could/would drain down over time,
Old Oct 27, 2010 | 7:47 AM
what are the pros/cons of placing a 2nd battery in parallel versus isolated? how many of you have gone to the trouble to add a second battery? thanks.
Dr Gary
Jul 21, 2014 5:01 PM
bossman79
Mar 12, 2013 8:08 PM
Chevy_gurl
Mar 2, 2010 1:01 PM
adamant
Feb 15, 2009 8:49 AM
guvner
Jan 7, 2008 4:16 PM
