2008 chevy utility body no lower brake or turn signals
Old Aug 13, 2019 | 6:05 PM
302wirenut's Avatar
Default 2008 chevy utility body no lower brake or turn signals
2008 chevy utility body no lower brake or turn signals. Upper brake light works fine. Could the problem be in the turn signal switch?
Old Aug 14, 2019 | 8:11 AM
a55bruce's Avatar
Rule out the turn signal switch by trying the hazard flasher.
No lights, check the wiring harness, connectors, ground connections, fuses, bulbs.
Check that the BCM connectors are tight and free of corrosion.
Do the front turn signal lights work with the hazard flasher?
Tmckinl1
Nov 20, 2017 8:39 AM
fraser jim
Feb 15, 2012 11:23 PM
ricky
Feb 4, 2011 6:50 PM
CodyB4C
Oct 14, 2009 11:19 PM
DERROLD
Aug 17, 2007 3:50 AM
