2008 GMC Yukon Break Controller Install
Old Feb 29, 2024 | 9:11 AM
holsonbake's Avatar
Default 2008 GMC Yukon Break Controller Install
Hi Guys:
I have a 2008 Yukon XL 1500. In connecting a 3ed party break controller, all seems normal until I get to the blue/white wire.
The two red wires are connected at the fuse box under the hood. Under the stearing wheel I found 4 wires. The white one is ground, the red wire has 12V all the time. The blue connects to the break controller and the blue/white wite is the signal. The blue/white wire has 12V all the time. I expected this to toggle on and off with the break peddle. What is your likely assumption or is there something I should verify? At this point I'm ready to shotgun the break peddle switch. Any suggestions?
Old Feb 29, 2024 | 9:23 PM
Welcome.
brake pedal.
You're going to need schematics. See if you can find one on charm.li
Old Mar 1, 2024 | 12:20 PM
holsonbake's Avatar
Clearfication to my original set of questions. Does the blue/white wire toggle 12V when pushing the break peddle?
Old Mar 1, 2024 | 11:11 PM
again,
brake pedal.
Old Mar 6, 2024 | 9:05 AM
holsonbake's Avatar
Hi Guys:
Replaced the break peddle switch and the signal wire started toggleing correctly,
Thanks for all the comments, good luck with all your GMC repairs!
dh
Old Mar 7, 2024 | 8:45 PM
LOL.
Brake pedal in English. Thanks for reporting back.
Williamsracing17
2007 - 2013 (GMT900)
11
Sep 22, 2024 3:40 PM
MoeSal
Aug 1, 2021 11:02 PM
reedbr
Aug 16, 2014 8:41 AM
danb113
Jul 15, 2010 5:07 PM
jpayne18
May 3, 2010 8:59 PM
