2008 LTZ Subruban blower motor issue
Old May 19, 2016 | 7:49 AM
  #11
jlowe84's Avatar
Default Same problem 2008 Tahoe LTZ
Originally Posted by zzuuzz
I have the same problem. I see lots of pre-2008 blower resistor replacements, but cant find anything on 2008 plus. 2008 suburban LTZ. Front blower sometimes doesn't come on, other times is fine. VIN 3GNFK16308G113022
I have been having the same issue for about a month, now My AC doesn't even work. The fan still stops/starts all on its own at various times, but I can't get cold air even though AC is running.
Old Jul 31, 2018 | 10:17 AM
  #12
hollie blake's Avatar
Hello, I am having this same issue where my fan either doesn't come on, or has a several minute delay and then will also fluctuate speed while it is on. The A/C is working when the fan does kick on. Also I will randomly get a very loud noise sometimes when i first turn on the vehicle that sounds like it is coming from the fan area, a grinding type noise. it only last a fewseconds and if I shut off the fan, it stops. 2008 Tahoe Z71. VIN 1GNFK13098R106337
Old Aug 24, 2020 | 1:58 PM
  #13
JohnDan's Avatar
Smile Front blower does not work
Hi, I went thru this message forum thread but did not see an answer as well. I saw a response about a recall on this issue but no resolution recommendation. The front AC/heater blower on my 2008 Suburban LTZ quit working. The on/off switch works and am able to adjust temperature and blower speed but blower is not turning on. I observed that the A/C compressor clutch will not engage either. I checked all related fuses and all are good. Any suggestion is appreciated.
Thank you in advance.
JohnD
Old Apr 7, 2021 | 7:00 PM
  #14
Red Wiggler's Avatar
Default Fixed
Fan was intermittent and we fast and slow. Bought resistor , didn't help.. I check for voltage on the fan power side.of the fan motor resistor and had 14 v. The fan is next to it. Easy to remove . Easy to replace.. the fan blows much harder as the blades were dirty on the old fan.
jbarbnolan
May 19, 2017 4:45 AM
jbarbnolan
May 18, 2017 5:05 PM
Steve Boddie
Jul 26, 2016 3:10 PM
Heidi Ann
Mar 31, 2014 12:54 PM
hobbyfarmer
Feb 2, 2009 9:24 AM
