Old Aug 10, 2015, 11:40 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
2008 Suburban cruise control not working
Old Aug 7, 2015 | 3:20 PM
  #21
Originally Posted by BurbinMomma
I was a bit confused a few months back because I was told to replace the "Brake pedal position switch". Oh, how incorrect...but it was cheap so I replaced it anyway. I ordered my Brake light switch from Amazon for $11 & it arrived today. The hardest part of the job for me was searching through hubby's tools and NOT finding a 10mm wrench. I substituted by using adjustable pliers (that kept slipping the adjustment) and a 10mm socket by hand once it was loose enough.
There's a decent amount of locktite on the bolt, so it took some force.
I will suggest a headlamp to give a little extra light without holding a flashlight in your teeth (yea, I tried that first).
Actual work time (minus unsuccessful tool location) was about 5-10minutes. Took my beastly Burb around the neighborhood and had working cruise for the first time in nearly 4 years!
If your cruise is out, skip the dealership & DIY!
2007 Burb 1500 5.3 V8, Z71
Good to hear!, thanks for taking the time to follow up on the fix working for you
Old Nov 16, 2016 | 8:29 AM
  #22
Justin Clay Powers's Avatar
My cruise control works intermittently. If it, all of a sudden, stops working, I gently kick the left side of the brake pedal, and it works again. Any ideas what the actual problem could be?
Old Mar 10, 2021 | 4:11 PM
  #23
ChevyMan08's Avatar
Question 08 Tahoe Intermittent Cruise
I have an '08 Tahoe and am experiencing the same intermittent cruise issue. However I have replaced the brake switch with the correct AC Delco one and now with a Napa one. All three are doing the same thing. However I have found if I tap the brake several times while tapping the set cruise button it will start to work. My local Napa person thought it was the brake switch being I could do that and get it to start to work. Additionally what I believe I've found is the cruise does not work after starting the vehicle, after messing with the brake as i just explained it doesn't fail me after that until I shut the vehicle off again. I sure could use all your thoughts on this so I can get to the bottom of the issue. Also researched the fuse to look at being there were no fuses labeled for cruise, I did find in the under hood fuse box number 43 fuse Misc/IGN. Also appears good. This is my wife's vehicle so you can imagine my wanting to fix this. She did her own research and thought it to be the cruise switch on the steering wheel. Although that is also not a super expensive part and I can replace it myself I'm trying not to be a total parts changer and find the actual root of the problem.
Old Mar 12, 2021 | 10:07 AM
  #24
repairman54's Avatar
It's a sensor also and not just a on/off switch and needs to be calibrated / adjusted correctly.
Old Mar 12, 2021 | 3:56 PM
  #25
ChevyMan08's Avatar
How do i go about calibrating and adjusting it?
Old Mar 13, 2021 | 8:09 AM
  #26
Scan tool that has that function. Should have had all 4 families of the system codes read anyway as that's the way of the modern vehicle today.
Sometimes you can get lucky by moving it slightly and testing repeatedly though.
Old Dec 13, 2021 | 11:02 PM
  #27
Shahid's Avatar
Hi, I have a 2007 suburban. the cruise control is not working properly. if i engage it after 80 the speed continues to increase even after setting on a speed. secondly the speedometer is not going above 80-90 even if the actual speed is above 100 or more. can anyone suggest a solution
Old Dec 13, 2021 | 11:06 PM
  #28
Shahid's Avatar
what did u do to fix the cruise control?
crwalker2
2007 - 2013 (GMT900)
94
Aug 28, 2024 3:27 AM
Esteban Fleitas
Oct 12, 2019 8:51 AM
Slackst3r
Jul 31, 2018 2:39 PM
Jamie Clay
Uplander
Mar 16, 2018 12:05 PM
Cody Sappington
Jan 16, 2017 7:03 PM
