2008 Suburban won’t start
Old Oct 29, 2019 | 7:14 PM
Nattydrd81's Avatar
Default 2008 Suburban won’t start
2008 Suburban 1500 LT 5.3L
Just finished a long block replacement. Leaving the coils & injectors unplugged and plugs out, I went to turn the motor over to prime the oil system. The first time I turned the key it tried to turn over but battery was too low. After charging I tried again but nothing happened. No click. Nothing. All the usual dash lights come on. Everything inside the cab works (windows, door locks, radio etc). The security light comes on and off in a couple seconds. The check engine light does not ever come on though. I got it to turn over and oil primed by jumping the start relay. It seems the ignition system will not energize with the key anymore.
Is there a problem with the ignition switch at the key? Or is this a BCM problem?
I need help!
Old Oct 30, 2019 | 1:48 PM
oilcanhenry's Avatar
I need help!
It has a non-serviceable fuel filter on the fuel pump so it could be clogged or bad fuel pump. Need to check fuel pressure with gauge. Might be a timing issue too or an electrical problem. Are you getting any OBD II codes?
Old Oct 30, 2019 | 2:04 PM
Nattydrd81's Avatar
Fuel system has full pressure. No codes.
Old Oct 30, 2019 | 5:09 PM
Are you getting any spark from the plugs?
Old Oct 30, 2019 | 6:30 PM
Nattydrd81's Avatar
No spark because the ignition circuit will not turn on.
Old Oct 30, 2019 | 7:50 PM
I need help!
I think you might have an issue with the camshaft sensor, or possibly the crankshaft sensor. Is the coil getting power? Could be the PCM or the ICM, but not likely.
Old Oct 30, 2019 | 9:21 PM
Irish_alley's Avatar
I'm here for the party
think im confused. will the engine turn over with the key or will it not just run? are you getting 12v to the starter signal wire on the starter?
Old Oct 31, 2019 | 11:06 PM
Nattydrd81's Avatar
The engine will not turn over with the key. I have checked continuity of all fuses. All good. Fuses that should have 12v when the ignition is on have 0v. I can only make the started work be jumping the start relay. I can’t find any ignition switch wire diagrams for a 2008 anywhere. ???
Old Nov 1, 2019 | 9:27 AM
have you tried starting in neutral?
Old Nov 1, 2019 | 10:34 AM
Nattydrd81's Avatar
Tried in neutral. No difference.
