2008 Surburban
Old May 1, 2017 | 5:01 PM
DDAVISON's Avatar
Default 2008 Surburban
Abs , stabilizer lites on & off
Dealer can't figure it out.
Started to have this problem after going threw high pressure car wash.
The lites come on for a day, go off and a month later comes on again.
When these lights comes on the truck seems to run ruff
Old May 2, 2017 | 9:52 AM
Scotiapilot's Avatar
Run your grounds, check grounds and clean them, some use dielectric grease, Do the same for your + positive cables. Check your ride sensors for open connections too. Check your battery leads to the starter.
I had 2003 denali with the same issues. I cannot ID the exact cause, but after doing what I recommended it cured the issues.
