2008 Tahoe Z55 autoride suspension control module
Old Apr 19, 2025 | 8:07 PM
dbtractor's Avatar
Default 2008 Tahoe Z55 autoride suspension control module
So this vehicle I put new rear shocks. front struts, and a new compressor on a couple months ago. Everything was working fine then a couple days ago I noticed the battery dead so I did a parasitic draw test. I measured a .5 amp draw and narrowed it down to 30 amp fuse #2 which powers the suspension control module and the air exhaust solenoid. I found that by removing the fuse my draw went down to .01 amps which is much better. When installing the fuse the solenoid clicked so the exhaust solenoid is getting a constant ground from the control module. I also noticed the compressor is not kicking on anymore. But I have no faults on the dash. I do not have a scan tool to check the faults.
I got access to the module and then checked power, grounds, and can communication. Load test powers and grounds. have good can communication. Also load tested ignition wake up and all that was good. Checked if there was a short in the solenoid control wire and there was not. I measured from the control pin on the module to the main ground pin and had 0 ohms so the module is constantly providing a ground to the solenoid even when completely unplugged. I also grounded the compressor relay control wire at the module connector and the compressor kicked on which verifies that all the compressor wiring and relay is good. At this point I'm suspecting a bad module. I heard there is a reset procedure or something, not sure if that would fix it. And I also don't know if I should have someone with a scan tool see if there are any codes because it doesn't have a fault on the dash.
Dvsdaniel517
Mar 6, 2024 7:54 PM
Viejito
Jul 26, 2023 8:30 AM
WELJ31
Jun 7, 2022 9:07 AM
Jesse9657350
1988 - 1998 (GMT400)
Dec 22, 2021 5:07 PM
randy4billsn3@Yahoo.com
Aug 21, 2016 10:19 AM
