2009 suburban low oil pressure p0521
Old Dec 8, 2014 | 10:54 PM
cisco190's Avatar
Default 2009 suburban low oil pressure p0521
hey guys new to the forum and need some help. the suburban is an 2009 ltz 1500 model 5.3 flex fuel. I have low oil pressure at idle with engine warm its anywhere between 10 and 20 psi . I put a mechanical gauge and that's what I am getting. now I have already replaced the oil pressure sensor,i have taken out the screen underneath it cleaned it and put it back and still no change. The oil level is perfect I am starting to think its my oil pump or a clogged oil pick up but don't wanna change those parts with out being sure. any suggestions are greatly appreciated. I even herd some where that the oil filter could be wrong and I should go with the oem filter
Old Dec 9, 2014 | 7:31 AM
SabrToothSqrl's Avatar
Default oil pressure
I've heard that the wrong filter can cause this on other engines, not sure about the GM one.
a new filter may be your cheapest fix. Worth a shot before you tear into something harder.
cisco190
Dec 21, 2014 5:11 PM
cisco190
Dec 8, 2014 10:37 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
MikeShirk
Dec 31, 2012 10:39 AM
