2009 Suburban LTZ factory camera module
Old Jan 6, 2011 | 11:26 AM
  #21
Attached
Old Jan 6, 2011 | 2:12 PM
  #22
bth62's Avatar
Originally Posted by ap53
16 Pin connector C4 on the back of the head unit.
Pin 6 Camera Signal #2 + (uvc)
Pin 7 Camera Signal #2 (uvc)
<O
I’m not sure about Voltage source to the camera.
<O
Thanks! That's what I'm trying to figure out
Old Apr 10, 2012 | 2:00 AM
  #23
inthemix's Avatar
12v + at Reverse you tap light green wire in the taillight and if you need ignition 12v+ use pink wire in the brown connector at the junction block under the drivers side of the dash.
Read this post it has it all.<O</O
https://chevroletforum.com/forum/showthread.php?t=22756<O</O
Hello guys...quick question on this one;
What if I do not have a pink wire in my BCM brown connector? This should be in cavity 7 of the (X12) connector but that cavity is empty! Worse yet, the BCM pin form that empty slot has no power!
I also do not have the back up light wire in my X11 connector which is the dark blue one in cavity 5...same issues as there is no pin in there anyway and no power from the BCM in that slot as well...
I have installed everything else from my Cubby Cam kit for the OEM back up camera on my nab unit and even programmed it with the Tech 2, but until I can find an ignition and back up source, all I am getting is a black screen with the safety message on top.
Thank you!
Jlo1984
Apr 10, 2022 7:57 PM
pjm333
Aug 19, 2015 3:40 PM
latif99
Jul 17, 2009 7:34 PM
latif99
Jul 17, 2009 3:18 AM
BigDrew
Aug 14, 2008 8:05 PM
