2009 Tahoe Rear HVAC Fan low speed only
Old Nov 10, 2019 | 10:03 PM
kshouman's Avatar
Default 2009 Tahoe Rear HVAC Fan low speed only
All,
I have a 2009 Tahoe and the rear HVAC fan only runs on low speed. It is an LS model. I have tried changing the module/resistor in the duct near the fan and it made no difference. Have not seen this problem discussed and I don't really know any trouble shooting I can do. Was thinking maybe replace the control switches, fan speed temperature, and vent but that is a guess also. Any help will be appreciated.
Thanks!
Old Nov 12, 2019 | 12:22 PM
oilcanhenry's Avatar
Originally Posted by kshouman
All,
Thanks!
Probably the auxiliary resistor is on the fritz.
Old Nov 12, 2019 | 8:44 PM
kshouman's Avatar
That is the part I changed, it did not change anything.
Old Nov 12, 2019 | 8:51 PM
then your high speed relay might be fried. Check a wiring diagram.
Old Nov 16, 2019 | 9:03 PM
kshouman's Avatar
Update.
Turns out the AC is stuck in mimic mode. Changing the front fan speed will change the rear. Also vent locations are controlled by the front.
Any ideas on what could cause this?
THanks.
Old Nov 16, 2019 | 10:23 PM
Tahoe_Hybrid's Avatar
the driver holds the master control
Old Nov 17, 2019 | 2:49 PM
kshouman's Avatar
Yes. The driver controls change the fan speed and vent location. It is supposed to revert to back seat control as soon as the back seat controls are moved but it does not.
Old Nov 22, 2019 | 6:33 PM
kshouman's Avatar
Does anyone know if this could be the rear controls on the ceiling? I don't have any adio controls, just HVAC.
stargate_k
Jul 29, 2020 6:18 PM
urdreamlady
Sonic (Aveo)
12
Jun 1, 2016 8:13 AM
xboxxer
Uplander
Dec 1, 2014 9:31 PM
thevan03
Astro
Mar 27, 2013 2:11 PM
nflguy
Aug 17, 2008 10:42 PM
