2009 Yukon problem
Old Sep 25, 2013 | 5:31 PM
bobby5201's Avatar
Default 2009 Yukon problem
Ws have a 2009 yukon with 45000 miles. Replaced the battery about a month ago and still having problems with it. Something itll just do the click click click thing. Checked the battery and its charged. The terminals are really hot though. Today my wife said the guages started blinking and tge yukon lost power and almost didnt make it home. Any suggestions? Thanks
Old Sep 25, 2013 | 8:07 PM
Welcome to the forum.
If the terminals are hot, then they must be loose. Make sure they're clean and tite.
Most auto parts stores will test the battery, charging system, and starter for free.
Was the old battery the original one?
Old Sep 25, 2013 | 8:14 PM
I would also add that if you live in a humid or salty environment, the cables may be internally corroded. The corrosion can also cause high resistance,
But like 73shark suggested I would suspect loose connections...
Check at the battery + to starter, battery + to fuse box, battery + to the alternator, battery - to engine block and the ground strap from engine to body and also that the alternators mounting bolts are clean, corrosion free and properly tighten...
CreepinDeth
Mar 15, 2019 1:09 PM
winkie74
Jan 2, 2014 11:28 PM
southbeach
Mar 20, 2011 10:22 AM
