2010 Suburban 2500 lift question
Old Jun 13, 2022 | 2:18 PM
Dlobi's Avatar
Default 2010 Suburban 2500 lift question
I've been rebuilding a front hit 3/4 ton suburban. Don't look too close at my paint job. Almost done but wanted it a tiny bit higher just for looks. Looking to add one inch blocks to rear axle and pull front up two inches with the torsion bars. Most kits are for a lot more lift. Finding just blocks for the rear but some confusing information with discrepancies. One set said for 2 1/2 inch axle only. Mine appears to be 3 1/2" tube. Also centering/locking pin listed as either 9/16 or 5/8 inch. Seems the 5/8 was 2019 and up or so and mine is a 2010. 8 lug of course. What size pin do I need? Also, can I get two inches out of the torsion bars? I assume I'll have to get front alignment but that's ok.
thanks in advance for any info.
Old Apr 2, 2023 | 3:48 AM
THBertson's Avatar
Just purchased a 2013 Suburban 2500!
I would like to do the same. Have you had any luck with doing the 1 inch back and 2 inch front?
Old Apr 2, 2023 | 7:45 PM
2inch on the torsion bars is the max...it might right rough at 2 inches.
Old Apr 2, 2023 | 10:17 PM
THBertson's Avatar
Thanks!
Jeff Dodson
Mar 31, 2019 1:54 PM
2010 4x4
2007 - 2013 (GMT900)
Jul 15, 2016 4:15 PM
jposey22
Feb 12, 2015 6:02 PM
The Chevro
Dec 18, 2014 1:37 PM
Droptine
Dec 2, 2011 5:00 PM
