2010 Suburban door handle popped off.
Old Feb 3, 2014 | 12:57 AM
610burb's Avatar
Default 2010 Suburban door handle popped off.
I tried to open my rear passenger sided door that was frozen shut and the door handle popped off. It doesn't appear that it is broken. Do I need to take apart the door to put it back together? There are two ***** one one end that appear to be the pivot point and a rectangle opening that looks like a metal piece goes inside it, like a bolt thru a washer...
Any suggestions
Old Feb 3, 2014 | 7:17 PM
Welcome to the forum.
IIRC, the handles are held on by screws/bolts from the inside which would necessitate removal of the door panel. You'll also probably need a new handle as unless the bolts broke, the threads are probably stripped out of the old one. I suppose you could use a heli-coil to repair them or epoxy. Check gmpartsdirect.com to see how much a new handle costs.
There was a report earlier that some of the handles got over-torqued upon assembled and started the failure mechanism.
Old Apr 14, 2016 | 3:09 PM
daveopal's Avatar
Drugar123
Apr 13, 2015 9:09 PM
tonyvisone
Mar 27, 2014 8:33 AM
aggie5151
Jun 1, 2010 10:04 PM
pnfireman
Oct 17, 2007 9:44 AM
