2010 Suburban Engine Replacement Advice
Old Jan 31, 2020 | 9:48 PM
Zeek T's Avatar
Default 2010 Suburban Engine Replacement Advice
Hello! I have a 2010 Chevy Suburban. I have terrible compression in cylinder one and have been burning oil. Pretty sure I can only replace the spark plug so many times before I need to buy a new engine or get rid of the burb. I have been looking at crate engines. I was thinking of buying a crate engine and having someone else install it. My main questions are:
What (if any) other engine models could I buy without the mechanic having to replace any other engine components off my current engine?
Any good suggestions as to who I should buy an engine from?
Looking to spend as little as possible, with a reliable outcome.
Thanks!!
Old Jan 31, 2020 | 10:32 PM
is the terrible compression on an afm cylinder? you may have a collapsed lifter.
when you buy an engine you get either a short block or long block. google the differences and check the costs to see what is more cost effective.
Old Feb 1, 2020 | 8:08 AM
Cusser's Avatar
If something you can live with, try a non-fouler, just screws into the spark plug hole and the spark plug screws into that.
Old Feb 1, 2020 | 9:24 AM
Zeek T's Avatar
I have an LC9 engine. I want to put an engine in without AFM.
Google is a swamp of random info, but I try.
chevynomore
Jan 25, 2015 10:10 PM
MarcusMiller360
Apr 4, 2014 7:43 PM
flh69
Oct 1, 2013 7:14 AM
levishness1
Feb 18, 2012 8:13 AM
Newburbian
Apr 11, 2011 7:40 AM
