2010 suburban tail lights
Old Nov 13, 2021 | 9:11 AM
badsled's Avatar
Default 2010 suburban tail lights
2010 suburban upper & lower bulbs are independent of each other, top and bottom,
i.e., brake, turn signal & 4way flasher. Has anyone re-wired so that both operate at the same time ?
Thanks, Jer
Old Nov 14, 2021 | 8:25 AM
repairman54's Avatar
With todays computer controlled lighting systems I would leave it alone. Any feedback to the BCM module could blow it up. Not worth the chance of hurting expensive modules by doing that just for looks.
Old Nov 15, 2021 | 11:42 AM
probably could be done using some diodes but you do have to careful with loads on the bcm so relays may be the way around it. Aftermarket leds lens assemblies may be already set up for this.
AlwxV
2007 - 2013 (GMT900)
May 2, 2020 12:04 AM
misterbodyrepairs
Jul 5, 2011 12:03 AM
Newburbian
Apr 11, 2011 7:40 AM
EvansBlue
ROTM Winners
Apr 5, 2010 2:53 PM
flagspeed
Mar 8, 2009 8:58 PM
