2011 Tahoe - coolant - Radiator Stop Leak ?
Old May 1, 2020 | 5:23 PM
Niels81gy's Avatar
Default 2011 Tahoe - coolant - Radiator Stop Leak ?
Hi,
on my 2011 Tahoe with 151k I am going to replace the coolant.
Is it worth to add a radiator stop leakage proactively? Like Liqui Moly Radiator Stop Leak or RAVENOL Professional Radiator Stop Leak?
Regards
Niels
Old May 2, 2020 | 7:22 AM
I would not use it if there are no leaks. When there is a leak it is better to repair the leak than to use a sealer.
Old May 2, 2020 | 9:04 AM
Cusser's Avatar
Agree
Old May 2, 2020 | 9:36 AM
Rednucleus's Avatar
Make sure you use distilled water vs tap water, your cooling system will appreciate it. The only thing I add is NAPA water pump lube (think it was called #13) on the advise of a radiator shop decades ago. No science there, but makes me fell better when I'm done!
Old May 2, 2020 | 9:01 PM
nope to any leak seal product it will swell and soften all rubber hoses
sharks17
Jan 20, 2018 2:31 PM
04tahoeowner
Jan 4, 2018 1:44 AM
99er
Apr 6, 2010 4:49 PM
72gator
Sep 28, 2009 12:12 PM
ffdaryl
Mar 1, 2007 2:52 AM
