2011 Yukon: Driver side seat belt buckle
Old Dec 17, 2021 | 12:43 PM
Cusser's Avatar
Default 2011 Yukon: Driver side seat belt buckle
2011 Yukon Denali: Driver side seat belt buckle would not latch; tried cleaning and lubing with silicone spray, no fix. I was totally unable to get the wire harness unlatched, as working totally blind, what a ridiculous piece of "engineering", that push an unseen latch while pulling apart, between the seat and the console. Harness could've been engineered/manufactured to have the disconnect near the part near the attaching hole; Thanks, GM !!!!
Anyway, I found that if Mrs. Cusser could insert the metal latch then push the red release button on the buckle about 1/8" down, then the buckle would catch and operate like it should.
Old Feb 19, 2022 | 12:50 PM
Cusser's Avatar
Buckle still working fine, using the workaround.
Fixed its left fog light (Mrs. Cusser didn't know it even had fog lights), was just a dirty female connector where it plugged into the fog bulb. I had tested the bulb itself, had noticed the harness for it just hanging free, and it had an aftermarket part label on it. Anyway, stuck 2 paper clips into that connector to test for voltage (which it had) and this time it worked after connecting it. Good, had bugged me !
hygene
Sep 8, 2018 9:41 PM
sjk
Captiva
May 15, 2015 2:46 PM
smokeatr23
Sep 10, 2014 6:34 PM
Proud83ElCaminoOwner
Chevelle & El Camino
Jan 1, 2014 10:52 PM
