2012 Drivers door control panel
Old Apr 23, 2024 | 7:38 AM
Culinary Rocks's Avatar
Default 2012 Drivers door control panel
I haven't started tearing things apart to check as I'm not sure where to begin. Here's the problems:
1) When the drivers door is open. None of the controls on the drivers door work (e.g. windows, heated seat, mirror controls....nothing).
2) When the drivers door shuts. Everything works except you can't lower the drivers window.
I'm assuming that the second point is that either that particular switch has failed or the motor for the window failed.
Sigh....
Any suggestions would be appreciated.
Thanks!
Old Nov 8, 2024 | 4:27 PM
hhergett's Avatar
Sigh....
Thanks!
Did you ever figure this out?
Old Nov 8, 2024 | 7:58 PM
Rednucleus's Avatar
Since it's sensitive to open vs closed I would be looking at the wiring thru the door, not the switch
Johnson556
Avalanche
Jan 22, 2018 10:10 AM
Nut210
2007 - 2013 (GMT900)
Dec 25, 2017 9:10 PM
cam2500hd
Jun 5, 2015 2:35 PM
chevy20006
Jul 19, 2011 12:49 PM
