2012 suburban Horn location
Old Apr 1, 2014 | 6:32 PM
squidboy's Avatar
Default 2012 suburban Horn location
I want to install a set of wolo air horns in my truck. From what I have seen the horns located somewhere behind the bumper and under the headlights. I want to be able to tap into the horn wire to make it work. Any one have any idea on how to get or find the wires
Thanks
Steve
Old Apr 2, 2014 | 11:14 AM
Desert Gringo's Avatar
remove the headlights, might have to remove the turn signal lens in front also
Old Apr 2, 2014 | 3:15 PM
SabrToothSqrl's Avatar
Default switch
wire in a simple on/off switch under the hood.
in PA you have to have a 'normal' horn to pass inspection.
Switch on = both horns.
off = factory only.
problem.. solved
Old Apr 6, 2014 | 6:08 PM
squidboy's Avatar
Thanks for the info. I just found a video on how to remove the headlight assembly. Are you friggin kidding me. You have to take the wheel well liner off and remove part of the bumper. That's nuts. That need to get done just to change the light bulb.
squidboy
Sep 4, 2014 7:22 PM
bowtie4j
May 4, 2012 10:46 PM
Joes02SIlverado
Apr 18, 2008 7:37 AM
isaac_22
Dec 26, 2007 9:23 PM
zulu
Mar 28, 2007 4:58 AM
