2012 Suburban LT 26" wheels Questions
Old Dec 20, 2012 | 1:15 AM
TheDetatchedMind's Avatar
Exclamation 2012 Suburban LT 26" wheels Questions
Hello everyone,
I just wanted to introduce myself and ask a couple of questions. So, let me begin...I am completely unfamiliar with SUVs and came from the car scene.
BMW 5 series (all Dinan)
Evo X (520 on pump, 750hp+ e85)
*Yes, I am sure alot of you will hate it but trust me..she was a beast.*
So I recently destroyed my Evo (1.5yr build & $30k motor build, awesome I know) and I am looking to switch it up a bit. I have read through a couple different threads on some of these answers but I was hoping to maybe get some fresh input or thoughts. (If I am retarded and missed an obvious thread feel free to point it out to me, id appreciate it.)
So here are my questions;
I am looking at 2012 LT 4x4 and putting it on 24" or 26" and lowering it.
1.) Do the 26" really tend to bend that easily? I don't plan on hitting pot holes but it just concerns me. (live in IL)
2.)How bad would rubbing be, if any? I plan on getting it professional done and aligned etc. Is it just plastic in fender that would rub? I am assuming it wouldnt be to hard to remove/fix.
3.) What are some good lowering options? Like I said I am a noob and would prefer to get a well recognized mfg. Any other personal experience please share as well.
4.) Any issues model wise to watch out for etc?
5.) I am looking into the following wheels;
DUB.1 ONE™ SIX Wheels - Custom Painted Rims (PREFERRED)
or
GIANELLE® COZUMEL Wheels - Black with Black Lip Rims
Thoughts? Murdered out is the plan with a little JL audio. This will be a daily driver.
Also, a Tahoe is an option as well but I just figured F it and go bigger since the prices seem be about the same if not better for Suburban
I appreciate everyone's input and once again, I apologize if I missed an obvious thread. Also, if anyone knows of a reputable shop in IL please share as well. (new to area and distance doesn't matter)
Thanks!
Old Dec 20, 2012 | 9:41 PM
15 Year Member
Welcome to the forum.
As far as rubbing on the inner fender liner goes, if it's mild, you can reshape it using a heat gun.
Personally I think anything over 22" makes it look like a covered wagon but to each his own.
Old Dec 21, 2012 | 10:23 AM
SWHouston's Avatar
When moving to a larger Diameter Rim, one can reduce the profile, to keep the Speedometer and performance issues at a minimum. However, the really low Profile Tires, are very vulnerable to Road Hazards. Elevated Air Pressures are a must, but, avoidance of a Hazard is going to be rather difficult.
Most of the rubbing problems which occur when doing this comes from someone trying to use a very wide tire. So, your problems will be less, if you don't overdo that.
A starting place for which ever vehicle you choose, is finding out what the OEM Tire Diameter is for it, and trying to match that as closely as you can.
PS:
If you're talking about a 1/2 ton vehicle, Pirelli has this 26" at the approximate OEM diameter...
Pirelli*Scorpion Zero Asimmetrico ($$$ WHEW ! )
henson50
May 19, 2014 8:02 PM
gunrnr
Aug 31, 2010 9:18 PM
chevyman323
Jul 16, 2010 11:56 AM
oldvet58
Mar 6, 2010 9:13 PM
mike688
Uplander
Jan 25, 2010 12:16 PM
