2012 suburban rear heater issue
Old Dec 8, 2016 | 7:30 AM
Proxjc's Avatar
Default 2012 suburban rear heater issue
My wife has a 2012 suburban. We noticed this summer the rear AC would blow slightly cold air and room temp air back and forth a few seconds at a time. Now this winter we are noticing that the heat is doing the same, slightly warm air to cold room temp air back and forth. Any ideas before I hit the dealer ??
Old Dec 12, 2016 | 8:10 PM
Proxjc's Avatar
Update, I took the trim pieces off the rear heater to see what was going on. When the rear heater is on, I notice that the rear dampener actuators are moving back and forth on there own. Letting cold air mix into the system. This is telling me it's a control issue. Next step is to find what controls those actuators, I'm guessing it on the console controls.
Old Dec 13, 2016 | 9:58 AM
05RedZ71Sub's Avatar
Is that the climate control adjusting the temperature output? Set the temp all the way to coldest or hottest and see if it remains stable.
Old Dec 13, 2016 | 10:04 AM
oldstuff's Avatar
You will need a bi-directional scanner to actuate the doors. Scanner will also show what the control panel is telling the doors to do.
Old Dec 13, 2016 | 12:47 PM
Proxjc's Avatar
With the setting all the way to hot or cold they fluctuate back and forth. Where could I find this scanner?
Old Dec 13, 2016 | 1:23 PM
oldstuff's Avatar
Most reputable repair shops will have one . The cheapo's at the parts stores do not usually have the bi-directional capability.
Old Dec 13, 2016 | 7:57 PM
Proxjc's Avatar
Haven't located a scanner yet, however I did take the control module out. When unplugged the actuated doors still move the same way. Back and forth randomly.
Old Dec 14, 2016 | 9:53 AM
oldstuff's Avatar
Check for codes with the scanner. Should be setting codes.
