2012 suburban transmission slipping
Old Aug 13, 2023 | 1:50 PM
Desertson's Avatar
Default 2012 suburban transmission slipping
Hello I have an issue with my suburban. My transmission is slipping. It will run just fine for about 5 min and then it won't catch any gear it just revs when I hit the gas. I tried putting it in manual no joy, 4x4 no joy. I turn it off and turn it back on and it will work again for a few minutes then slips again is this the solenoids going bad or is it the transmission that's toast. Thank you in advance.
Old Aug 13, 2023 | 3:38 PM
Miles on the vehicle please?
You can check the transmission fluid level and condition. A mechanic with a professional tool and run diagnostics on the transmission. That's about all you can do.
An 11yo transmission is probably toast though. Average lifetime is about 125k. Less if it was never maintained.
Old Aug 14, 2023 | 8:02 AM
Desertson's Avatar
Hello and thank you for the reply. It has 168k miles on it so I guess it might be toast. I just think it's crazy that it will drive for a few miles then just give out.
Old Aug 14, 2023 | 3:01 PM
line pressure is higher when the transmission is cold.
You might be able to squeeze a few more months out of it with some transmission additive (Lucas, etc.). But I would have a plan B ready.
Old Nov 21, 2023 | 6:22 PM
Blondie70's Avatar
Is the filter plugged ?
Old Nov 21, 2023 | 6:46 PM
KEVINLAWHORNSSE's Avatar
I have an 07 and got 195,000 before the bad day.
I put an aftermarket cooler on it from day one.
I also changed trans fluid every 50k
cannibal carl
HHR
May 20, 2021 10:08 AM
alpineskye
Jan 31, 2018 7:59 AM
Davpmars
Jul 15, 2017 8:03 AM
MegaMiles
Feb 16, 2011 4:52 PM
ballz
Dec 6, 2008 4:17 PM
