2012 suburban z71 p0300 because of torque converter????
Old Jan 17, 2023 | 8:03 PM
Corey1987's Avatar
Default 2012 suburban z71 p0300 because of torque converter????
Hello, fellas.
Im looking to see if any of y’all have heard of a torque converter causing a p0300 code.
I’ll try to make this short as possible. I forget all the codes but it started with running lean, then heat resistor to certain cylinder misfires.
durning my repair process I have replaced:
injectors
plugs
wires
all o2 sensors
All possible leaking vacuum lines
2 coil packs (where I was getting an individual cylinder misfire)
MAF
all A/C delco parts.
my fuel pressure at the rail starts at 60 psi then while warm runs about 43ish.
during all of this my torque converter felt like it failing so I took it to a transmission shop, he agreed the torque converter felt like it was going but suggested I solved the codes first. Now I can cycle the truck several times without it throwing a code, but when I get it on the road after a while… when decelerating, it will shudder, then the check light will blink for a bit and then the p0300 will stay on. Is it possible the computer is getting confused because of a bad torque converter???
any help is appreciated!!!
Old Jan 21, 2023 | 9:33 AM
repairman54's Avatar
Are you scanning all 4 code families? They are P, B, U and C. You can have issues in the U codes for example that will not show up on a P code scan tool.
mcivatte
Oct 14, 2021 11:32 AM
Smithsfan
2007 - 2013 (GMT900)
Apr 7, 2021 6:51 PM
heynow68
Dec 16, 2011 8:14 PM
cobalt89
Aug 30, 2009 2:38 PM
jfink
Dec 20, 2008 7:21 PM
