2013 Tahoe TPMS showing crazy
Old Dec 10, 2017 | 11:23 AM
  #11
shirazy747's Avatar
Dear IN2PRO,
Me 2 dear (going jinx) but not giving up until I ahve my baby back to normal.
Thank you so much for the help
Old Dec 10, 2017 | 11:39 AM
  #12
The TPMS batteries are encapsulated in the sensor itself and are not replaceable. You have to replace the entire sensor. You can get them on eBay for about half the price of what GM charges which I understand is not even an option for you anyway. Can you do PayPal?
Old Dec 10, 2017 | 6:06 PM
  #13
Suburban Dude's Avatar
Very interesting. Each of the 4 TPMS sensors contains one battery. It is molded in plastic and is attached to the tire inflation valve. The batteries as far as I know are not replaceable. If you want to remove a TPMS sensor, you need to remove the tire from the rim and unscrew the nut that secures the TPMS sensor to the rim. A new set of 4 TPMS sensors is normaly less than $100 US. Good luck.
Old Dec 11, 2017 | 5:22 AM
  #14
a55bruce's Avatar
Originally Posted by shirazy747
2- I have done the reset procedure twice and I will do it again sir .Yes I did the youtube thing it required 8-10 second deflation, no horn honk or chime sound but reset worked fine for a couple of hours, then warning back again.
On my 2011 Tahoe it takes 30-45 seconds of deflation before I get the horn chirp / light flash. Unless they've changed the procedure since 2011, if you're not getting the horn chirp the relearn is NOT finishing learning where the sensors are located..
Update....
According to the 2013 owners manual, deflating the tires will not work while doing the relearn procedure. You'll need a TPMS tool to set the sensors during the relearn.
Last edited by a55bruce; Dec 11, 2017 at 7:34 AM. Reason: Looked at the 2013 Owners manual
Old Dec 11, 2017 | 12:41 PM
  #15
There is probably a tire shop or Chev dealer somewhere in your country who can do this.
SD
Old May 28, 2018 | 3:49 AM
  #16
klimbik's Avatar
I made a video to show all people how to relearn tpms sensors, so hopefully this will help
enjoy!
one sensor cost about $8 on aliexpress and workes good for few months
