2015 Suburban Sputtering
Old Feb 13, 2021 | 9:10 AM
chiefsport's Avatar
Default 2015 Suburban Sputtering
Hey everyone. My 2015 Suburban LTZ is sputtering like misfires when under light acceleration.....kind of a quick jerking as acceleration stalls. When you give it more acceleration it goes away. It isn't throwing any codes. I am running premium gas, so I'm not sure it is a fuel quality issue. I took it to my normal mechanic and he said "this is above our head, you may need to take it to the dealership...we can't figure it out. Fuel is only getting to half of your engine." While I don't mind taking it to the dealership, that is always my least favorite option. I was seeing if someone here has had this before and could give ideas, just so I am prepared for if the dealer starts trying to take me for a ride. I have about 93,000 miles on the vehicle. I tried to search the forum and saw some fuel pump ideas, but it was on older models.
Old Jul 16, 2024 | 8:56 PM
Smitty7373's Avatar
Default What kind of forum is this?
this question was posted in 2021? And not one single response. Is this forum a waste of time.
Old Jul 16, 2024 | 9:15 PM
Rednucleus's Avatar
Hey Smitty, nice 1st post; give us a chance, lots of good info here for you
Old Jul 17, 2024 | 3:18 PM
2015 Silver Suburban's Avatar
Torque Convertor Shudder? Well I see where gas is only getting to half the engine supposedly. Nevermind on the torque convertor shudder.
Old Aug 1, 2024 | 6:29 PM
Tahoe2525's Avatar
Default Same problem
I have a 2016 with the identical problem, did you find a fix?
Old Oct 26, 2025 | 2:17 PM
Debing Roadside's Avatar
Default This
If all the evap has been checked and replaced. Fuel pump is going or (unfortunately more than likely) high pressure fuel pump. Lines on it are one use as well. Thanks to the GM engineers.... it is under the intake manifold. Older chevys also had this issue but with fuel pressure regulator, also under intake.
Aaron Heimbecher
Mar 26, 2020 6:33 PM
ryanerickson
Dec 10, 2017 1:48 PM
libgentech
Oct 12, 2017 5:26 PM
Deville64
Apr 21, 2017 11:15 PM
hoagiesgarage
Oct 7, 2014 11:19 AM
