2016 Suburban LTZ no power to blower motor
Old Feb 22, 2023 | 8:39 PM
rodp14's Avatar
Default 2016 Suburban LTZ no power to blower motor
Hey yal my blower stopped working up front-rear works fine.
Checked the fuse on the passenger side- along with just about every fuse in the drive side and engine bay. They all tested fine for continuity.
I currently have no power to the blower.Checked the negative and positive leads on the cable going to blower with a DMM as well as the connection on the rail.( there is a short run where the hot goes into a connector then up in the dash out of sight-hooked hot end to DMM and grounded other end to vehicle to test)
It has no resistor which I wasn’t aware of until after I looked for it for 2 hours.
I can here the vents open and close when I change directional settings. I can also hear something actuating when I turn the power on to HVAC unit up front. But still no power.
That’s all I got.
Any help would be appreciated. Chevy wants to charge 120$ just to look at it.
Old Feb 23, 2023 | 7:41 AM
04Z71SuburbanDude's Avatar
what I would do is (only do this when you know you'll have access to the car all day and you are also free all day) go to AutoZone and buy a blower motor. install it, see if it works. if it doesn't work take it back and you'll get your money back and you are dealing with a bigger problem. if it does work, then it was the blower motor it self.
Old Feb 24, 2023 | 8:00 AM
Cusser's Avatar
He stated no power to the blower motor, so not the motor.
Old Feb 26, 2023 | 6:52 AM
repairman54's Avatar
Spend $20 at alldata for a one month access to a real shop manual so you can properly diagnose it.
Old Feb 26, 2023 | 10:18 AM
Rednucleus's Avatar
Jump 12v to the motor to prove it works, then you can continue with your diagnostic challange
Old Apr 17, 2023 | 6:53 PM
Tadpole81's Avatar
Did you ever figure out the issue? Mine is doing the same thing.
ScottyD
Nov 11, 2021 12:15 PM
ykkrs
Oct 26, 2020 6:29 PM
Dw288
Apr 19, 2020 1:19 AM
Wes Tripple
Aug 10, 2019 2:09 PM
Srock67
Jan 1, 2014 12:19 PM
