2021 - Suburban Duramax - Need to find a switched fuse to use for a
Old Jul 29, 2021 | 7:30 PM
jadederea's Avatar
Default 2021 - Suburban Duramax - Need to find a switched fuse to use for a
I am trying to find a fuse to tap to run a led light accessory I only want to have power when the Diesel is on.
The standard (Gas) user guide has fuses in the engine compartment on page 334/335:
The Diesel supplemental guide has a fuse block in the engine compartment on page 50/51.
I think what is making this tricky is I have the Diesel Duramax so my fuses are different. It doesn't have the ignition fuse based on the supplemental guide. Am I wrong?
What do you think I can tap into that is only powered when the Diesel is running?
Old Jul 30, 2021 | 7:22 AM
repairman54's Avatar
Test light and probing. I had to run a wire from underhood fuse box and use a fuse tap to get a ignition switched source for my radar detector in my '11.
Baz
Dec 22, 2024 5:01 AM
Jason PM
May 29, 2021 10:24 AM
Danielhurlbert
Mar 18, 2019 1:39 AM
Ronald Tobias Hughes
Oct 26, 2016 6:51 PM
Christopher Krumholt
May 17, 2013 6:10 AM
