2021 Tahoe Premier Tire Pressure Monitor
Old Mar 9, 2021 | 2:23 PM
dszpara's Avatar
Default 2021 Tahoe Premier Tire Pressure Monitor
After rotating tires on the 2021 Tahoe do I need to reprogram the tire pressure minitors or will they program themselves?
Old Mar 9, 2021 | 10:24 PM
they need to be registered to the new position with a registry tool. the tool is pretty cheap.
if not done the system still works....just shows the old position.
not required for dodge products cause they run 3 additional Id modules
Old Mar 10, 2021 | 5:37 AM
dszpara's Avatar
Thank You!
Old Mar 10, 2021 | 8:10 AM
Gumby22's Avatar
The driver information center should give you the option to relearn the sensor positions. Without an activation tool, a strong magnet (such as a speaker magnet) will work, or you can let up to 10 PSI of air out of the tire while in learn mode. The horn will honk twice when learn mode is activated, once for each learned sensor, and twice when the whole process is complete (or if it times out).
Start at the driver front, then passenger front, passenger rear, driver rear.
Learn mode will time out after 2 minutes, regardless of whether or not all the sensors are learned.
Old Mar 10, 2021 | 9:01 AM
dszpara's Avatar
Thank You!
dszpara
Mar 12, 2021 11:26 AM
vicki200usa2002
Cobalt
Dec 8, 2017 12:00 PM
Scotiapilot
Jan 30, 2017 7:25 PM
flappytango
Sep 20, 2015 2:47 PM
mijonq
Nov 28, 2007 6:52 AM
