2023 Suburban sway bar low ground clearance fix?
Old Dec 1, 2023 | 12:50 PM
jrosenlund's Avatar
Default 2023 Suburban sway bar low ground clearance fix?
Greetings. Was wondering if anyone has a fix for this. I have a 2023 Suburban. Was disappointed to take it out in the hills and find that the ground clearance is terrible...The sway bar sits at 7-8 inches off the ground, but the real problem is that it's at that height all the way across the vehicle. So pretty hard to straddle anything, etc. Was wondering if anyone knows of an aftermarket sway bar that tucks up between the frame? Thanks in advance for your ideas.
Old Dec 1, 2023 | 4:02 PM
Interesting. Do you have a photo from the front showing this?
Old Dec 1, 2023 | 4:12 PM
jrosenlund's Avatar
Default Photos of 2023 Suburban rear sway bar
Didn't have one from the front, but here's one from the rear and the side. Seems like it could have been tucked up in there a little tighter.
View from rear of 2023 suburban sway bar
View from side of 2023 suburban rear sway bar
Old Dec 1, 2023 | 4:48 PM
Rednucleus's Avatar
Cowboy cadillac's are not off road vehicles lol!!
Old Dec 1, 2023 | 4:49 PM
ohhhhhhh it's a REAR sway bar.
Yeah, that does look kinda dumb. But does it hang below that rear suspension crossmember?
Old Dec 1, 2023 | 4:53 PM
jrosenlund's Avatar
The side view shows how it is mounted below the frame and then runs straight across. The crossmember at the wheel is lower yet, but it's not very wide. The sway bar is about 7" off the ground all the way across the vehicle. Like having a rear differential all the way across the back...
Old Mar 6, 2024 | 7:05 AM
hanky's Avatar
Is there any way you can check another same vehicle and see if they are all like that? If so maybe GM can offer a suggestion to reduce that problem?
Lindale
Jun 28, 2023 6:49 PM
Tom Colson
Dec 19, 2020 10:20 AM
curtis1512
Dec 11, 2017 10:02 AM
SOLOLUCKY
Apr 16, 2015 10:32 PM
RockVegas
Aug 31, 2013 5:08 PM
