24's vs. 26's
Old Aug 21, 2007 | 9:27 AM
  #11
SWRidin's Avatar
Default RE: 24's vs. 26's
Your right. There is a big difference between 315/30/26's and 305/35/24's.
I was comparing the 305/30/26, since this is the most popular size i've seen.
I've never seen anyone run a 315/30/26. It should be obvious to everyone that that tire is too big.
26's with minimal clearance issues requires you run a 305/30/26 rubberband.
Old Aug 22, 2007 | 12:50 AM
  #12
dtme46's Avatar
i have 24s on my hoe right now on a 2/3 drop and i dont like how it looks to much of a wheel gap so im going to go with26s soon 305/30/26 a guy here in my townhas an Escalade on a 305/25/26 tire my buddy said itrides like ish(he hasdriven the Escalade) i just hope my hoe dosentride that bad
Old Aug 22, 2007 | 9:24 AM
  #13
GIXXER's Avatar
dtme46 --> Would love to see some pics!
Old Aug 22, 2007 | 7:37 PM
  #14
w00t's Avatar
Thanks for everyone's help and advice, I pulled the trigger on TIS 26's... Sorry for the poor quality pic, will get some high rez one's soon.
[IMG]local://upfiles/10923/223894A11E9A4D5EAEA6107577805770.jpg[/IMG]
Old Aug 23, 2007 | 8:52 AM
  #15
dtme46's Avatar
gixxer do you want pictures of myHoeor the guys Escalade? w00t how much did you pay for your 26s? it looks hella clean
Old Aug 23, 2007 | 11:58 AM
  #16
GIXXER's Avatar
sorry, I meant yours...I couldn't find any pics of it
Old Aug 23, 2007 | 12:04 PM
  #17
SWRidin's Avatar
w00t that looks awesome!
How is the ride?
Old Aug 23, 2007 | 12:06 PM
  #18
SWRidin's Avatar
dtme46,
Going 24 to 26 isn't going to reduce your wheel gap.
You'll just have more rim and less tire.
Want less gap... drop more.
Old Aug 23, 2007 | 12:43 PM
  #19
w00t's Avatar
So after only 1 day here are my observations about the converstion from stock wheels/tires to 26's..
[ol][*]Definitely notice sloooooow starts off the line, guess it takes much more torque to get those beasts rolling. Wondering if I should have gone Denali instead of the LT3 to get the bigger motor + 6 speed instead of Flexfuel - basically they are the same price.[*]At highway speeds it's much less likely to kick into V4 mode?!!? Even a moderate downhill w/cruise control on.[*]Ride quality is as expected, not bad but noticeably choppier then stock. Definitely acceptable in my opinion.[*]Clearance. No major problems thus far, heard minimal rubbing when entering steep driveways at low speed or when turning hard at low speeds. I suspect a little fender well trimming may be required, more updates to come.
[/ol]26's without lowering is by far the way to go. Still have clearance for when I need to go into 4WD, and the fender wells fill out really nicely. I couldn't imagine the ride quality with big wheels AND lowering springs... Save the $$ on the lowering kit (and alignment) and get 26's
Old Aug 23, 2007 | 2:46 PM
  #20
ORIGINAL: w00t
[ol][*]Clearance. No major problems thus far, heard minimal rubbing when entering steep driveways at low speed or when turning hard at low speeds. I suspect a little fender well trimming may be required, more updates to come.
[/ol]
You might try a heat gun on fender liners before cutting. Sounds like it won't take much. Others on this forum have reported that the heat gun approach works well.
