2nd Battery Tray?
Old Nov 16, 2019 | 10:41 PM
  #51
Tahoe_Hybrid's Avatar
Originally Posted by ZX1100F1
There were several reasons that th battery was moved to the upper passenger side of the engine compartment.
Weight distribution, vibration isolation, crash test and aftermath results being a few of them.
Wrong it's safe to have it there and makes it easy to replace it basically a 30min job turns into a 1min job
for me it actually took more time to buy it in the store(about 35min) then it took to pull it out and put it in..
the 45 pound battery does not help you will need a 200 pound bag of concrete to set up any type of Weight distribution
that is how much the avg american weighs
but even on consumer models it's in the front driver side hybrid models they put the high voltage inverter in the other location.
it's a pain to replace the filter though but i practiced several times and able to get it off with ease
Old Apr 26, 2022 | 2:37 PM
  #52
Bluedawg's Avatar
Originally Posted by in2pro
gabenderthat is the same thing I thought also, just back fed into the sytem via those studs, they do provide power to the accessories when the ignition is off, HOWEVER I don't know if starting power would be pulled back thru that same circuit which could be a bad thing... If you do a forum search for AUX battery there are several topics on the matter but this particular thread seems to have the best info on the addtion of the extra battery
have you tried rockauto.com
Old Apr 26, 2025 | 3:14 AM
  #53
1vwood44's Avatar
New User
Awaiting E-mail Confirmation
Yes and so far I have had no issues, the Aux battery is back feeding the circuit that is why you have the extra power for accessories but when you crank the engine your accessories turn off and in that same function it prevents the aux battery from being used to provide starting / cranking power.
So basically you used the left 30A stud (with small red wire) to go straight to the 2nd battery? What is your connection onto the right leading to? I don't plan on running a trailer or nothing so would I leave that one open?
Scotiapilot
Mar 15, 2016 12:35 PM
Deek
Jun 27, 2015 8:30 PM
TAHOE2005
Jun 1, 2010 9:19 PM
ChilisPapa
Dec 9, 2008 3:36 PM
norrislaketn
Nov 25, 2008 6:03 PM
