4WD/Check Engine Problem (2005 Tahoe Z71)
Old Aug 26, 2009 | 10:19 AM
ejj's Avatar
ejj
Default 4WD/Check Engine Problem (2005 Tahoe Z71)
This morning when I started the truck, I was greated both of the following:
- A check engine light
- The 4WD selector switches only blink when pressed (Auto, 2H, 4H, 4L), and the Netural light is lit.
Does this combination indicate anything in particular? I assume some sort of electronics problem with a transfer case controller or something similar.
Any harm driving the car like this? The front axle drive is not engaged, so I'm not overly concerned. I have a 200 mile commute home Friday...
Thanks!
Old Aug 26, 2009 | 7:11 PM
ejj's Avatar
ejj
For what its worth, the gear selector was in 2HI after I left work today, and worked properly. Just like nothing happened.
Still have the CEL though.
Old Aug 28, 2009 | 12:24 AM
Most auto parts stores w/ pull your codes for free. Might point in the right direction.
Old Aug 28, 2009 | 8:22 AM
ejj's Avatar
ejj
Pulled the code last night. P0446 - EVAP....so I don't think that's related to the 4WD problem.
Since that morning, everything behaved fine...
Old Aug 28, 2009 | 11:05 PM
Did you check the gas cap?
Old Aug 29, 2009 | 7:35 AM
ejj's Avatar
ejj
Yes, its on properly.
redrotor
Cobalt
Aug 29, 2019 8:38 PM
D Chevy
Sep 17, 2012 12:06 PM
CaptEd
Apr 25, 2012 10:00 PM
GAT57
Aug 2, 2009 7:04 PM
meatball
Nov 1, 2006 8:41 PM
