#7 misfire
Old Oct 7, 2011 | 1:09 PM
cyras21's Avatar
Default #7 misfire
Tahoe started running rough this weekend. Last night the CE light came on and coded for #7misfire. I swapped out the coil pack with #1 and reset the light. This afternoon the CE light came back on, again misfire #7. Is this a spark plug and wire issue or is there something else I can check?
All wires and plugs were changed less than 25k miles.
Old Oct 7, 2011 | 1:23 PM
I would walk all three items to the opposite side of the engine.... but yes it could be a plug and or wire....might try running some injector cleaner thru also..
did you replace them with OEM or aftermarket plugs wires?
Old Oct 7, 2011 | 2:08 PM
cyras21's Avatar
yes, thanks
Old Oct 8, 2011 | 2:20 PM
cyras21's Avatar
replaced #7 spark plug and let it idle for about 5 mins. so far no misfire. This is what the old spark plug looked like after 23k miles. Is this caused by excessive oil consumption?
Old Oct 8, 2011 | 2:39 PM
kevinkpk's Avatar
Looks like detonation
NGK Spark Plugs USA
buddyleno
Mar 31, 2017 8:13 AM
Biggumzmcgee
Nov 15, 2009 10:51 AM
JetSnake
Jul 14, 2009 2:43 PM
akimber
14
Aug 22, 2006 11:45 AM
bmc257
Jul 7, 2006 3:21 AM
