85 Burban oil leak
Old Jun 10, 2012 | 9:28 PM
85chevyman's Avatar
Default 85 Burban oil leak
I have an 85 Burban with a newly (8kmiles) rebuilt 350 it sat for roughly 6 years after being rebuilt and driven for about 5k miles. I believe the front main seal is bad as there is oil leaking from behind my alt and fan. It is a small leak where I don't notice it. But when I shift into OD it shoots oil onto my headers and smoke just swallows the rear of my truck. I am wondering if there would be a quick nd easy fix or if it could be something other then my front main seal since it gets worse only in OD. I lost 3 gear and drive in 2 up to 50mph and it doesn't smoke then when I shift into OD it does them stops when i shift out of OD. Please if anyone knows anything to help I'd appreciate it very much
Old Jun 12, 2012 | 4:31 PM
JWEEZY's Avatar
Thumbs up remove pulley to fix front main
Originally Posted by 85chevyman
I have an 85 Burban with a newly (8kmiles) rebuilt 350 it sat for roughly 6 years after being rebuilt and driven for about 5k miles. I believe the front main seal is bad as there is oil leaking from behind my alt and fan. It is a small leak where I don't notice it. But when I shift into OD it shoots oil onto my headers and smoke just swallows the rear of my truck. I am wondering if there would be a quick and easy fix or if it could be something other then my front main seal since it gets worse only in OD. I lost 3 gear and drive in 2 up to 50mph and it doesn't smoke then when I shift into OD it does them stops when i shift out of OD. Please if anyone knows anything to help I'd appreciate it very much
I believe you remove the pulley usually with an impact wrench to fix front main.
I fixed a 6.2 Diesel once by dropping the oil pan, reshaping the front of the oil pan a bit and then installing a cheap gasket bingo wasn't the front main. I have done a rear main before wasn't hard. I would make darn sure it just isn't the oil pan and/or gasket maker most use. I use gaskets whenever possible haven't had greatest of luck with gasket maker!
Old Jun 12, 2012 | 6:24 PM
85chevyman's Avatar
On I will look into that. Thanks a lot for the advice
Eric Sherden
Sep 24, 2013 1:21 PM
PastorK
Mar 1, 2010 9:09 PM
95wt
May 30, 2008 3:07 PM
trush
Jan 1, 2008 9:27 PM
larry_chip
Apr 24, 2007 11:46 AM
