'85 Tailgate power window not closing fully - spring backwards?
Old Jun 16, 2021 | 4:38 AM
botmans's Avatar
Default '85 Tailgate power window not closing fully - spring backwards?
Just got a '85 Suburban and fixing a few things on it. The rear window won't close fully, it stops with 2cm's to go.
I pulled out the window, motor, regulator etc and cleaned it up. It works a little bit better.
What I found strange is that the regulator spring gets tensioned when the window goes up. So the motor has to work against the gravity of the window and the spring.
Would make more sense to me that the spring would help the motor lift the window instead of working against it. When opening it also drops down very fast, probably due to the spring.
Can it be the the previous owner put the spring on backwards?!
Thanks!
Old Jun 20, 2021 | 7:03 PM
Welcome to the forum. It's definitely either on backwards or the wrong spring.
jettyspicer
Mar 27, 2015 10:46 AM
highroad
Dec 6, 2014 11:18 AM
rdc
Aug 31, 2014 3:43 PM
thx569
Nov 4, 2012 9:08 PM
goinliveinfive
Apr 2, 2008 3:05 AM
