94 Suburban won't start
Looking for a little help here. I have a 94 suburban that has been giving my all kind of grief. My most recent problem is that it died on me the other day and won't restart. It is behaving as if it isn't getting fuel. I have tested the relay and the fuse for the fuel pump and they are good. There is no sound of the pump trying to engage when I try to turn it over. I forced some starter fluid into to see if it would engage, but no luck. It appears as if it isn't getting any juice to work. I am about to dig into the wiring, especially at the pump side. But I am looking for other ideas just in case. By the way, the pump was replaced about a year ago, so I hope that it's not bad already..
x2. I would still look at the fuel pump. And like shark says double check for spark.
I just chased my tail for like a month on my pickup because I refused to believe the ignition module I had replaced less than a year ago went south again... a new coil and lots of head scratching and wire checking later, I swapped out the module and brought bessie back to life.
:chug:
ZChevyAK
November 13th, 2015 6:45 PM
larry_chip
June 2nd, 2007 3:20 PM
