94 Suburban won't start
Old May 11, 2011 | 7:03 PM
Hereticfred's Avatar
Unhappy 94 Suburban won't start
Looking for a little help here. I have a 94 suburban that has been giving my all kind of grief. My most recent problem is that it died on me the other day and won't restart. It is behaving as if it isn't getting fuel. I have tested the relay and the fuse for the fuel pump and they are good. There is no sound of the pump trying to engage when I try to turn it over. I forced some starter fluid into to see if it would engage, but no luck. It appears as if it isn't getting any juice to work. I am about to dig into the wiring, especially at the pump side. But I am looking for other ideas just in case. By the way, the pump was replaced about a year ago, so I hope that it's not bad already..
Old May 11, 2011 | 8:36 PM
Welcome to the forum.
Check your fuel pressure. If ether didn't fire, maybe you got no spark?
Old May 11, 2011 | 8:55 PM
hicksvilleshick's Avatar
x2. I would still look at the fuel pump. And like shark says double check for spark.
I just chased my tail for like a month on my pickup because I refused to believe the ignition module I had replaced less than a year ago went south again... a new coil and lots of head scratching and wire checking later, I swapped out the module and brought bessie back to life.
:chug:
Old Jun 18, 2011 | 2:49 PM
David99's Avatar
i have a spark and 55 psi fuel pressure but still no start
Old Jun 18, 2011 | 10:03 PM
Probably get more response if you just start a new thread than asking in several existing threads.
ZChevyAK
Nov 13, 2015 6:45 PM
bracca
Jul 12, 2009 6:14 PM
FamilyOf5
Jun 11, 2008 2:56 PM
sklevans
Nov 28, 2006 3:47 PM
